587,787 active members*
2,304 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Servo Dynamics SD4-1525 Shunt Regulator
    Nov 2008
    24
    I have a Yeong Chin Supermax (Bridgeport clone) circa 1989. It has servo dynamics motors and amps ( SDF-1525-12).
    Lately the X axis VOL LED is tripping frequently. Otherwise the axis is running normal and turning it by hand has normal resistance.
    I have a manual for the amps which says that nuisance tripping of the voltage LED may indicate the that the shunt regulator fuse may be blown. It also says that the shunt regulator fuses are optional. My manual doesn't indicate where these fuses are located. Are they on the amp board or on the chassis? Is there one per amplifier or shared? How do I know if I have them and how do I test?
    If that isn't the problem, what else might be the issue?
    Aug 2009
    1573
    Re: Servo Dynamics SD4-1525 Shunt Regulator
    ...dirty Tach brushes can cause this. The Shunt Reg is the Unit in the lower left in this picture
    Nov 2008
    24
    Thanks!
    My doesn't look quite like the picture. The unit in my chassis has space for three fuses. Only one is populated and the fuse isn't blown. I'll try cleaning the tach brushes.
  1. MX4660 shunt regulator option
    By TMToronto in forum Leadshine
    Last Post: 10-05-2021, 03:24 PM
  2. Servo Dynamics 1525-BR Manual
    By atgordon in forum Machinery Manuals / Brochures
    Last Post: 12-16-2015, 12:14 AM
  3. Replies: 1
    Last Post: 11-06-2014, 04:43 PM
  4. Replies: 0
    Last Post: 05-08-2013, 04:54 PM
  5. Servo Dynamics SD4-1525-10-3-10 chassis power needs?
    By erikjgreen in forum Servo Motors / Drives
    Last Post: 01-06-2012, 06:21 PM
