603,936 active members*
2,244 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Servo faults are showing up again
Results 1 to 6 of 6
    Sep 2004
    235
    Hi
    I thought I had my problems with servo faults solved. Art had
    mentioned to set Mach3 to sherline mode. That seemed to end the errors
    on the X axis servo. Just to play it safe I ordered shielded and
    twisted paired cables and line drivers from US Digital. Now that I
    have the cables and driver installed for the x and z axis the x is
    faulting again. It always seems to be the direct drive servo on the x
    and never the z. I have the Rogers machine encoder interface card so
    it will stop the machine if the following error gets too large. A few
    weeks ago I was cutting a 3D part at 100 ipm with a following error
    set to .005. Now I have the following error set to 1 inch and the axis
    faults after it moved .5 inches.
    I`m lost.
    Barry
    Dec 2005
    390
    I wish I could answer your question but I can't. It does sound like you have some ideas that are very interesting though. Could you describe your setup a bit more? What is this encode card you mentioned? What does the Sherline mode of Mach do? Should everyone who is running servos have that set? It is really neat that you have an idea of when the machine is off the required accuracy and stops.
    May 2006
    5
    servo faults showing up again
    bgolash,
    I am not familiar with the set up you are speaking of, but i have
    repaired/troubleshot a few cnc machines. It sounds like your machine is scewing for some reason. Does your machine have a master/slave setup
    or is it a cantilever type(1 x axis or 2 x axises). Check your drive motor(s)
    feedback (counting,pulses etc.)to see if maybe you are missing a signal.
    Besides that look for a mechanical problem( pinion teeth, socket/belt slipping.
    Since I'm not familiar with your machine I would need more info. Hope this is a little help. Liston336
    I spent a half day trying to find out why my CNC in Y was skipping a palts.
    I could not see any thing. I finely put some WD-40 on it and the problem went away. Made me "mad". Well, such as home prew CNC's.
    God bless
    Aug 2005
    828
    Quote Originally Posted by wildcat View Post
    He is talking about this:
    http://www.rogersmachine.net/encoderinterface.html
    Barry,
    You are scarring me I bought the card also will have my router ready for testing in a few weeks.
    You mentioned direct drive servo on the X, maybe it pulls enough amps to cause EMI interference.
    Do you have Geckos?
    Dennis
    Sep 2004
    235
    Servo success
    Hi All
    I`ve still had a difficult time with vibration on the x axis servo
    and faults that occurred at slow jog speeds. I contacted Marisss and
    he suggested the 3 changes below. I`ve just done the changes and the
    x is acting normal. No more strange vibration and x movement on its
    own. Without jogging the axis it would move in short moves repeatly.
    So, for what ever reason bypassing the interface board seems to
    solve the problem on the x axis.
    I still have the z on the Rogers Machine encoder interface card and
    it works perfect. The only difference I see is the new encoder wires
    are now grounded to the G320 instead of the interface board. I wonder
    if noise was a issue before.
    (1) Connect the encoder directly to the G320. When you do, remove
    the 470 Ohm resistor. This is to eliminate any adverse contribution
    from the encoder board while you troubleshoot. With the encoder
    interface card the wires from the encoder were going to the
    interface board and then to the G320.
    2) Set GAIN and DAMP to the 11 o'clock position (a little less than
    half-scale). Set LIMIT fully clockwise.
    3) DO NOT keep increasing the fuse size. You will eventually find
    one big enough to blow up the drive if you do.
  1. Servo Amp Faults
    By Karl_T in forum Servo Motors / Drives
    Last Post: 04-05-2007, 03:48 AM
  2. VFD drive Faults on series I cnc Bridgeport
    By colin1544 in forum Bridgeport / Hardinge Mills
    Last Post: 09-22-2006, 11:36 PM
  3. Website Showing My CNC Conversion
    By chris59 in forum Machines running Mach Software
    Last Post: 01-20-2006, 07:08 PM
