603,967 active members*
1,983 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Servo jitters at idle
    May 2017
    58
    After rebuilding a harness and finding a broken wire in the x axis limit switch i regained power to my x axis. It now occilates when the amps are powered up. If i swap boards it stays at x of i swap harnesses it stays with x. Y axis does not jitter when swaping iether and acts notmal except it sounds very faintley like it speeds up a milisecond then goes back to normal for a revolution or so then up thrn back. I tried the board tuning for the servo dynamics amps and also rezeroed then retuned. It will take input for movement while jittering but does end up faulting out. Voltage looks good from power supply at 4.9 11.9 and 25.8. When a tech came for the orriginal issue I tried to see if it would jog from the servo tune menu but because of the disconected limit switch it would not. Did i screw up the tune as it auto saves to matrix 4? Its a diffrent servo then the orriginal as the old also occilated and i thought bad encoder. Does it need to be re-tuned? This is a hawk 5m dual screen sd amps and baldor servo
    May 2017
    58
    After trouble shooting and loooking I wondered if thr tach leads were opposite on the x harness vs y. Flipped them and seem to have gotten it back under control. Seems i keep answering my own problems sorry to hog the forum space.
    Quote Originally Posted by Sandvet03 View Post
    Feb 2006
    191
    Re: Servo jitters at idle
    On the contrary Sandvet03 , I think your post will help others to identify similar issues.
    Thank you for the follow up and great to hear the problem was resolved !
    Rich
  1. 4th Axis Servo motor Oscilate when idle
    By dexter910 in forum Servo Motors / Drives
    Last Post: 01-25-2018, 05:31 PM
  2. Servo Jitter / Oscillation when idle
    By jim_cliff11 in forum Servo Motors / Drives
    Last Post: 01-15-2018, 02:44 PM
  3. Mazak humming servo at idle
    By gusf in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-21-2017, 08:23 PM
  4. Z axis servo has been getting hot sitting at idle
    By williamsmotower in forum Charter Oak Automation Support Forum
    Last Post: 08-28-2015, 03:44 AM
  5. Suddenly I have Servo Jitters on the Z-axis
    By Deltic_Engine in forum Fanuc
    Last Post: 03-08-2010, 03:25 AM
