603,940 active members*
2,136 visitors online*
Results 1 to 7 of 7
    Mar 2014
    1141
    Servo motor for CNC Lathe project
    I'm willing to build a CNC lathe. The most important part for me is the spindle motor. As far as I know it must be a servo to control the revolutions for threading.
    The distance between centers will be 400-450mm so it is not that big but I will cut hard stainless steel or equivalent materials in hardness. Can you help me finding a suitable servo motor that is not so expensive.
    I found this motor on e bay but I don't know if it is strong enough for the machine.
    New Dunkermotoren BG63X55 Brushless DC Servo Motor PLG52 GearHead B CNC DIY | eBay
    Thanks in advance
    Suat
    Mar 2014
    1141
    Re: Servo motor for CNC Lathe project
    ... or can I use a Nema style stepper motor as spindle?
    Oct 2010
    1189
    I use normal elektro Motor and Vfd but an encoder on the spindle i would use normal steppers for x and z axis . I think high speed servo aß Motor is possible but May be too Slow
    Just my 5 cents
    Mar 2014
    1141
    Excuse my stupid question. So what is the best way to make a lathe if you want to cut thread mostly? I only used manual lathes and they include gears to make threading possible but if I am to build a CNC lathe it doesn't need to have any change gears. Am I correct? So how the machine synchronize the speed of the spindle and the cross slide to cut a thread?
    Oct 2010
    1189
    Hi
    there are no stupid questions
    it is true you don't need gears anymore on an cnc lathe ,..
    i googled for you "linuxcnc lathe thread"
    and all the links explain it more or less how it works
    my favorite is Lathe Spindle Encoder
    i would use an CUI AMT103 encoder but that is just details
    thomas
    Mar 2014
    1141
    That's a neat idea. Now I'm thinking of rotary encoders. Can Mach3 work with it?
    Oct 2010
    1189
    I dont use Windows only if i get paid more Than 100€ / hour ...
  1. cool servo motor project by noob
    By regaljohnston in forum Servo Motors / Drives
    Last Post: 01-29-2013, 04:03 AM
  2. Lathe Variable Spindle motor options? VFD? Servo? Stepper? DC?
    By whiteriver in forum CNC Machine Related Electronics
    Last Post: 03-17-2011, 01:38 AM
  3. Servo motor for Lathe & 4th axis
    By skip20 in forum Mini Lathe
    Last Post: 04-16-2008, 04:02 PM
  4. Servo motor build project...
    By WilliamD in forum CNC Machine Related Electronics
    Last Post: 11-27-2006, 08:35 PM
  5. servo as spindle motor for manual lathe.
    By thx1138 in forum CNC Machine Related Electronics
    Last Post: 08-24-2006, 08:54 AM
