After removing the plastic pulley, I found that the motor shaft diameter is .234 inches. The new pulleys that I have, have an inside diameter of .250" This causes a slight wobble. What would be the best way to correct this situation ? Should I try to lathe out a small sleeve, .016 aluminum foil etc. I have also completed the prototype reducer assembly, here are some pictures.
