Hi
I have a multicam 5000 series with a servo problem. The problem being that the bearings in the Z axis motor have seized due to lack of grease. It has obviously been dry since new as there is not even any residue to suggest that there has ever been any lubrication. I have replaced the bearings and i`m up and running again but I would like to have a at least one spare motor for future quick repair . The problem i`m having is sourcing a new motor as the original manufacturer ( In the U.K. at least) has been bought out & no longer deals with servos. Below is the info on the motor :
MCG 1500North front street
Part number - 3486 - ME 4698 - F
MFG code - 001509 0616
Cust No - 54 - 00102 - 00
Tcont : 18.13 LB-IN Icont6014 AMPS
Vrated : 170 VDC Speed : 6000 RPM
Does anybody know of a suitable alternative manufacturer as I would be prepared to replace all three motors . A straight swap out would be ideal . The original motors were built in China ( Which explains alot ) although the machine is American made . Can`t help thinking that if all the component parts were made in America then things would last a bit longer . Buy cheap buy twice. Or buy Chinese and always have you r hand in your pocket !
Any help would be appriecieated. Thanks
Syd
