603,942 active members*
2,837 visitors online*
Results 1 to 4 of 4
    Nov 2005
    28
    Servo Resolution
    I have a damaged servo encoder on the back of a 1KW motor. Motor damaged in shipping !!! It is a 500 CPR, can I replace it with 1000 CPR or are motors and encoders matched. 500 CPR only gives 0.01 mm per step and I would like better. (Drive from a 3d milling machine) Thanks Wallace New Zealand.
    Dec 2005
    3319
    Probably but you'll be sure to have to "tell your computer" somehow about the CPR change. This is usually don in a paramter list or configuration file that the controller refers to at start/boot up.
    Otherwise, you'll probably experience a drastic change in the feedback response characteristics
    Dec 2003
    24260
    Quote Originally Posted by kiwiavi View Post
    You did not mention what controller you have, as NC mentioned, you will have to rescale the feedback resolution, most sytems multiply the basic count x4 so the 500 was giving you 2000c/rev a 1000 B.C. enc. would give you 4000 counts/rev.
    Also what to watch for is if the motor is a BLDC or AC servo, the commutator tracks may be on the encoder disk.
    If DC motor then there should be no concern over this.
    Al.
    Albert E.
    Nov 2005
    28
    The motor is a Torque Systems. It is about 2 KW DC. It has a tacho feedback and a Data Technology Encoder on the end of the shaft mounted within the motor housing. It was driven with a Westamp (or Servo Dynamics) 140Volt 20 amp Controller. I am changing to Mach 3 and Uhu controllers.
    To see what happened to my mill http://www.briancad.itgo.com/
  1. Resolution / Accuracy
    By The Blight in forum Linear and Rotary Motion
    Last Post: 09-14-2006, 11:29 PM
  2. Stepper resolution
    By dfwiii in forum Stepper Motors / Drives
    Last Post: 07-18-2006, 01:54 PM
  3. resolution of axes
    By lazyscotsman in forum Uncategorised MetalWorking Machines
    Last Post: 03-17-2006, 01:43 PM
  4. Stepper Resolution
    By Max in forum DIY CNC Router Table Machines
    Last Post: 09-05-2004, 09:06 AM
  5. Resolution
    By Laff Riot in forum CNC Machine Related Electronics
    Last Post: 05-29-2003, 08:03 PM
