I have just recently converted from steppers to servos on my CNC router and have a few questions. for setting up the steps with my steppers it was 200 steps per rev. on my servos I have 250 CPR encoders which I believe it means that their are 1000 steps per revolution or is it 250 steps per revolution? I am also using a 2:1 reduction turning a 5/8" .200 ball screw.
2nd question I am having a hard time getting the home/ limit switch to work. I am trying to have the home and limit switch be the same switch on the three axis. I can get it to hit the limit switch and stop the machine even if I am homing. once limit switch is made how do I reset to get the machine off the off the limit switch. Is there an override of some sort other than turning the machine off and moving it by manually?
thanks in advance.
Planeflier.
