603,960 active members*
2,527 visitors online*
    Aug 2004
    8
    servo voltage
    I have servos on my router build and they are rated for 60v maximum voltage. my power supply puts out about 65v. The motors seem to work ok and they always feel cool, but I cant get them to run anywhere near the rated rpm. Could running higher than maximum voltage somehow cause them run slower? Seems it would be the opposite to me. Any info appreciated
    Dec 2003
    24260
    RPM is dependent on voltage and the recommended P.S. voltage is usually a minimum of rated motor voltage +10% so you should be just at bare minimum of the recommended.
    The drives may not be getting the maximum command from the controller?
    Al.
    Albert E.
    Jan 2005
    15362
    dhaddox
    If you are running Mach, you are limited by the pulse out put, this is what controls the speed,of your servos The higher you can get the pulse rate up in Mach the faster your motors will run, other than going as high as can with Mach, & your computer runs ok with a higher setting, the next step is a smooth stepper or something like it to get a higher pulse rate
    Don't go higher with your Voltage you won't see but a slight difference, in RPM, You are already 5v over the drive Max
    Mactec54
  1. AC Servo voltage
    By HuckMilton in forum Servo Motors / Drives
    Last Post: 11-25-2008, 04:47 PM
  2. Voltage and Servo motors
    By dgalaxy in forum Servo Motors / Drives
    Last Post: 11-24-2008, 04:11 PM
  3. Fanuc DC servo, what voltage?
    By Jonne in forum Fanuc
    Last Post: 09-21-2007, 03:27 PM
  4. Servo maximum voltage
    By bgolash in forum Servo Motors / Drives
    Last Post: 04-12-2006, 01:45 AM
  5. servo motor voltage?
    By tpworks in forum Gecko Drives
    Last Post: 04-17-2004, 08:34 AM
