603,954 active members*
3,301 visitors online*
Results 1 to 7 of 7
    Mar 2006
    20
    Set the counter display
    Dear frend !
    Iam Nguyen Van Hien , from Vietnam , I have the CNC Lathe Fanuc OTB , I can not set the counter & the timer in the monitor display , If you can , help me please or send me the link to load
    Thank you
    Jan 2006
    44
    Parts counter and timer are Fanuc options. Have you got theses options?
    Alan B
    Jun 2006
    478
    Most timmers can be reset by using the the cursor down key to highlight the the time on the the command screen and then typing, zero and input.
    Aug 2006
    12
    In order to reset it you have to be in MDI mode, high light it with the curser and type 0, input. That should work it does on my KIA with the fanuc otb.
    Dec 2003
    24260
    This is from the manual.
    Al.
    Attached Files Attached Files
    Albert E.
    Mar 2006
    20
    My Machine is Tong-Il TNL 20 Fanuc OTB , the counter have not , I think it hidden and can set from parameter.
    Sep 2005
    31
    Can you set parater No.900 - 916? If u can set I wil told you.
