603,924 active members*
3,640 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Set new Datum *problem*
    Feb 2014
    31
    Hello Guys,
    I`am using Partmaster Lathe V13 and have a Problem... i want to machining a turning objekt from a imported dxf file. how can i set the datum on the right side of this pulley?
    thanks,
    Andy
    Attached Thumbnails Attached Thumbnails Bildschirmfoto 2015-03-15 um 10.47.28.jpg
    Feb 2007
    417
    Re: Set new Datum *problem*
    Hello
    In CAM - chose the Setup icon from the bottom toolbar
    Then choose the Origin tab, next to the Origin sizes, Z and X click the select button - it's the mouse pointer with a ?
    Move the cursor into the graphics area and right click the mouse - then choose "Near XY extents of the geometry" (this is the same for mill and turn which is why it's XY - but it still works)
    Next, move the mouse to the far right of the geometry on the centreline - the mouse will "snap" to the position you require - left click the mouse.
    You will see the new sizes in the ZX windows, next check the box "Align geometry origin........"
    Hope this clear
    Andre
