I was thinking about building my own cnc machine for some years now so some weeks ago I started designing.
I am building boats at school and at home (raptor canoe) so it has to have some area. My father is going to do harps and I plan to mainly work with wood (boats, modelplanes, furniture and bikes) and XPS for plugs and surfboards.
Planning on running my Makita700C router before upgrading to a CNC Spindle. Should be enough for some plywood cutting.
My current design iteration has 1620mm*920mm*145mm working area from 1800mm*1000mm*300mm guide rails.
Some design inspirations are
EMS (Möderl/mixware.de) machines. There is also a lot of his design work available on his sites and on the webarchive pages.
http://www.ems-moederl.de/index.html
"Frida"
https://www.google.at/search?q=FRIDA+Fr%C3%A4se&safe=off&espv=2&biw=1600&bih=770&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjpn5qV2rvPAhWBchQKHSgbAPAQ_AUIBigB
JRHarris
http://jrharris.co.uk/#section6
Welschoff's CNC-Wood
http://ww3.cad.de/foren/ubb/Forum502/HTML/000001.shtml
http://ww3.cad.de/foren/ubb/uploads/...d/DSCF2706.jpg
CNC14
http://www.cnc14.de/
and Openbuilds OX
Linear rails
20mm on Y (2 carriages on each), 20mm on X (one carriage on each rail) and 25 or 30mm on Z (one carriage).
The Y and X axis will be beltdriven (15mm HTD3M) where the belt is interfacing with a rack. Or belt on belt but it looks as the belts do not interface that great that way.
I am also here for some advice on Motors and controllers. At first I thought about buying a Longs Motors Set for 200€ (convenient as it ships from a German warehouse) but it is not well matched.
I guess they stepper motors should have a low impedance (<2mH) and I need a 48V PSU.
So here are some pictures of the current design.
http://docdro.id/z1xOSIY (PDF drawing, side view)
There will be a vertical vise on the front end of the table. Maybe a removable bed or a tilting part like on Frank Howarths cnc (Joe's Hybrid) and the CNC14.
Here are my previous design iterations. The one under the stairs was not a serious idea though concrete side walls would be cool. Initially I wanted to build in wood but aluminium extrusions and T-slots are just too convenient. I also thought about V bearings on steel but why when good linear components are available at good prices.
I already post on a German speaking forum but the reach of CNC-Zone is much higher and I figure more opinions can't hurt.
thank you,
