603,826 active members*
3,635 visitors online*
    Oct 2009
    26
    Setting table size
    I just got my JGRO up and running for the first time this weekend. While assembling it I managed to break one of my DumpsterCNC AB-nuts so I am not able to run the z-axis, but have both x and y running. I made a pen mount for it so that i could at least seem some fruits of my labor and draw pictures of what i would be routing. very cool. However, there is something wrong with the scale of my machine. When drawing the EMC splash screen g-code "EMC2 Axis" it only draws it about 1/4" tall, i think it is supposed to be larger than that. I also tried making some drawings in Inkscape and converted them with gcodetools and they worked, however they are much smaller than they are supposed to be as well. I don't really know where to start trouble shooting this as this is my first machine and first attempt at using cam and controller software. Any thoughts? Thanks
    Mar 2009
    106
    Congratulations on your new machine. Don't be discouraged by the small problems you're having. You probably need to run the step configuration wizard again. My suspicion is you simply made a math error with your stepper setup. In case you haven't found it yet this is a good guide: http://www.linuxcnc.org/docs/EMC2_Getting_Started.pdf
    Good luck!
  1. Need Help Setting Up Used Table
    By ASMCO in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-16-2010, 11:13 PM
  2. Setting Size of cutout
    By Crawdaddy in forum PlasmaCam
    Last Post: 10-08-2009, 10:04 PM
  3. Setting Table Height
    By Sam A in forum Commercial CNC Wood Routers
    Last Post: 03-07-2009, 10:57 AM
  4. Setting Material Size
    By dgoddard in forum MadCAM
    Last Post: 09-09-2007, 05:07 AM
  5. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 06:21 PM
