603,333 active members*
3,461 visitors online*
Results 1 to 5 of 5
    Sep 2003
    1490
    Setting up - Dialing in 3D printer
    PRINTER: Maker Select Plus 3D Printer (Approximately 8 hours run time)
    SOFTWARE/SLITTER: PrusaSlicer 2.5.0
    This printer is probably 3 years old, I purchased it new in the box, tools never unwrapped or assembled, the factory test butterfly still on the build platform.
    I initially ran it with the version of Cura it came with, however having a lot of stringing.
    Found the YouTube user named Grimm, he had the same machine and was running the PrusaSlicer, and since I’m a total newbie I asked him for his configuration of PS, he went further than that and posted a video as to all the special configurations and after correcting a spelling error on my part it worked with my machine perfectly.
    Now I want to dial it in and optimize the settings.
    I didn’t know what testing to start with so I picked a couple in the photo below.
    The Top back side of the cube is a little concaved, however the bottom of the cube on that side is very straight. The Y side has some ghost imaging to the right.
    Any comments or suggestions for these conditions?
    I also ran a Briging test, the large wheel type print. There is some fine stringing, but I really don’t know what this is really testing. Could someone comment on this test.
    Could someone suggest what tests I should be running to optimize this machine?
    HH
    Unable to post photo so I’ll post this and reopen and try posting a photo later.
    Sep 2003
    1490
    Re: Setting up - Dialing in 3D printer
    Here’s the photo.
    Mar 2017
    411
    Gosh, you have bitten off a lot. New to 3D printing and new build it yourself machine.
    In my experience:
    You should print out a Benchy and post up some high resolution photos of the results. You will get your best response that way.
    Also, ghosting is usually a symptom of poor rigidity. Make sure your belts are tight and it will reduce the ringing in the mechanics that causes the ghost image.
    Start by testing the mechanical things first. Straight lines, extrusion temperatures, bed adhesion, testing should come before stuff like pressure advance and retraction distance.
    Just my $.02
    Nov 2007
    483
    Tuning out stringing is mainly from two settings. Retraction and nozzle temp. With direct drive extruders 1mm is a good starting point. Temp is filament dependant. Most PLA's can be printed around 200 and petg around 240. Start with a stringing tower test. Thingiverse is a good place to find calibration models. Something like https://www.thingiverse.com/thing:2080224 will do. PLA for example, start the stringing test like any other print, then change the nozzle temp manually at given intervals. Look at https://www.thingiverse.com/thing:3477606 if you want the model to indicate when you change temps.
    What are your general print settings? Speeds? Walls, top and bottom thicknesses? Cooling?
    It's generally best to start with a flow calibration test. If you don't know how, a quick Google search is all you need to get started.
    This is critical and often overlooked when it comes to the dimensional accuracy, stringing, and the finish of your part.
    You should do it for every spool of material you have and save it to the specific material profile in your slicer.
    If you have a quality supplier for your materials it usually won't change much from spool to spool (of the same material), but it's a fast print and there's really no reason not to check it.
    Once you've calculated the value it can sometimes be a little low, but you can really dial it in 0.5-1% at a time after that.
  1. Homebuilt pcb printer from cheap HP printer
    By LazyH in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 02-11-2020, 10:06 AM
  2. Help dialing in precision
    By 2_many_hobbies in forum DIY CNC Router Table Machines
    Last Post: 08-14-2018, 12:56 AM
  3. Troubles dialing in A axis
    By CricutDude in forum Machines running Mach Software
    Last Post: 08-12-2014, 04:59 PM
  4. dialing in a 4th axis?
    By RP Designs in forum Vertical Mill, Lathe Project Log
    Last Post: 08-04-2011, 02:09 AM
  5. dialing in tools....
    By Stifler51 in forum Haas Lathes
    Last Post: 03-03-2010, 10:21 AM
