603,893 active members*
2,807 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Setting Up a Drill Bit Model In SprutCam
Results 1 to 4 of 4
    Dec 2009
    458
    After viewing several tutorials on how to model a typical Drill-Bit in my SolidWorks CAD software I finally got it done. I thought that all that was needed now was to import it as an IGES file into my SprutCam software in order to create some G-Code.
    Actually what I modeled is meant to be a Spiral-Fluted-Reamer. In the past I've made Straight-Fluted-Reamers with ease using SprutCam and the 4th-Axis on my Tormach mill. Unfortunately for me, by adding the Spiral-Flutes on my Reamer/Drill-Bit, the same procedure I used to make my Straight-Fluted-Reamers just doesn't work any more.
    Can one of you more experienced SprutCam guys or gals give me a clue on how you would go about creating tool paths for a generic Drill-Bit model?
    With the Straight-Flute-Reamers I've made in the past, I've used the 2D Contouring feature under the "Finishing" icon to create my tool paths. With the Helix or Spiral flutes added, I can't get the 2D Contouring feature to cut along the length of the flutes. The best I've been able to do is to use the "Rotary-Milling" feature; and that doesn't cut from front to back or back to front. In the simulations, it causes the end mill to cut in any of a number of ways except for the full Back to Front cutting while the 4th-Axis simultaneously rotates to create the Spiral or Helix grooves that forms a Drill-Bit.
    A little help please.
    Thanks in advance.
    MetalShavings
    Aug 2009
    610
    Re: Setting Up a Drill Bit Model In SprutCam
    Hey Metal Shavings,
    I don't want to recreate the wheel here so I suggest you watch our favorite Russian go through this 2 part series where he combines rotary machining operations and 2D contours. It helped me a ton while manufacturing some rotary molding equipment. It was great and actually explained some of the settings that were mysterious to me before- I'm not thinking in Russian yet, but I'm getting close Comrade :-).
    Start with this one
    4ax milling - YouTube
    and then view this one
    4ax milling2 - YouTube
    I also liked the pocketing demonstration
    4ax pocket - YouTube
    Aug 2009
    610
    I enjoy watching Eric's tutorials and these tutorials because they compliment each other well.
    Dec 2009
    458
    I came across these videos posted by this fellow before posting my inquiry on this forum. I've watched and re-watched them a few times over but, I still can't get it to work for me. This same guy has a video that deals specifically with what looks like a drill bit/auger-bit that I've viewed several time but there too, I just can't get it to work on my Drill-Bit-Model. I'm kind of wondering if it's my SolidWorks model that may be causing the problem.
    On the video links you've posted, it appears that this gentleman is working with a five axis milling machine. I don't know if it makes any difference but, I'm working with a 4-Axis milling machine.
    I haven't given up just yet. I know it's possible to machine a drill bit using the fourth-Axis on my mill. I just need to figure out how it's done.
    MetalShavings
  1. Replies: 12
    Last Post: 03-28-2013, 09:27 AM
  2. setting drill on osp-500 control
    By spock in forum Okuma
    Last Post: 09-25-2012, 01:49 PM
  3. Replies: 3
    Last Post: 10-30-2010, 04:31 AM
  4. setting a drill &/or a c/drill on a cnc lathe
    By warren01 in forum CNC Machining Centers
    Last Post: 01-20-2010, 08:31 PM
  5. Setting up a gang bang drill holder
    By joseavina76 in forum MetalWork Discussion
    Last Post: 10-02-2006, 04:28 PM
