588,069 active members*
4,968 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Setting up first axis step/dir on KFLOP/KANALOG - No 'C'-experience
Page 6 of 6 456
Results 101 to 109 of 109
  1. #101
    May 2006
    4052
    Re: Setting up first axis step/dir on KFLOP/KANALOG - No 'C'-experience
    KFLOP
    TK
    http://dynomotion.com
  2. #102
    Mar 2022
    70
    Quote Originally Posted by TomKerekes View Post
    KFLOP
    First select on Configuration Screen Ch0 when i move by hand Kflop output bit state not changing
    When i make for Ch1 it change
  3. #103
    Mar 2022
    70
    Everything change when i was working the main power supply Off after a hours we get power when i turn on the PC it display error Helpctr.exe, I close it and start Kmotion
    Then when i power up the main Switch both Axis Run so fast i can't control everything, i switched the main switch
  4. #104
    May 2006
    4052
    I can't understand. It doesn't matter what axis is selected on the Configuration screen when looking at all the axes on the Axis Screen. Explain exactly what youare doing and what bits change. If you can not explain simple things you are doing I can not help you. Please put more effort into your responses.
    TK
  5. #105
    Mar 2022
    70
    Hi Tom
    I decide to start again from the beginning, install KMotion435f
    On Digital IO Screen Kflop Enc 1 Aand Enc 1 B is not changing that means state shows blank
  6. #106
    Mar 2022
    70
    I thought to use window 10 and the last Kmotion version will take more time but i did it it work fine
  7. #107
    May 2006
    4052
    I don't understand
    TK
  8. #108
    Mar 2022
    70
    I start with window XP with Industrial computer
    Yesterday after power failure everything becomes difficult ( here power failure is common, transmission line and other things cause failure )
    I start read how can i use window 10 that i use in laptop and i did
    And i copy the PCB that control the Plasma
    To tell you the truth Tom i spent for this machine above 15 hours each days
    Now i stuck on that Axis,
    I open encoder to check the encoder glass and circuit it looks fine and i check when i move from step screen Axis move and glass rotating and i check their will be dust, glass is clean.
    So what shall i do next ?
  9. #109
    May 2006
    4052
    It’s very simple to test an encoder. Apply +5V. Measure each of the 4 outputs (A+ A- B+ B-) with a Voltmeter. The outputs should toggle between < 0.4V and >2.4V if not the encoder is bad and needs to be fixed or replaced.
    TK
Page 6 of 6 456
  1. Kflop with STEP/DIR output
    By funding33 in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-01-2021, 04:49 PM
  2. KFlop to step/dir spindle
    By macona in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-14-2017, 09:06 AM
  3. KFlop how to configure spindle as Step and Dir No output for DIR
    By vetsen in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-08-2015, 07:08 PM
  4. KFlop with KAnalog Step and Dir for Yaskawa SGDH PULS/SIGN inputs
    By DeanW in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-02-2013, 08:37 PM
  5. Kflop Dir / Step setup time
    By BobKinsman in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-16-2012, 12:10 AM
