603,960 active members*
3,485 visitors online*
Results 1 to 5 of 5
    Dec 2008
    10
    Setting up form tools
    Hi guys,
    I have been using SolidCam since Christmas and find it very easy to use, however I have come across a small problem which I hope some one can give some advice on.
    I have to create a profile using a form cutter. I need to have the diameter size referenced to the smallest diameter of the form tool and to Z reference to the centre line of the radius form. (See attached image)
    Any help will be grately received as we do quite a bit of work using form tools and need to set them in this way.
    regards
    Steve
    Jun 2009
    10
    You are looking for information on "shaped tools" The geometry is based upon a sketch. See SolidCam help shaped tools
    Regards
    GDG
    Dec 2008
    10
    The help file has no useful information about what I am wanting, sorry.
    What I need is a reference point which can be moved about the shape and not dictated to by SolidCam.
    Oct 2007
    499
    To have a reference point moved around the shape is not possible, but there are solutions.
    The thing I would do is define the shaped tool in "Shaped Tools", assign it to a tool in the library (probable an endmill would be best) and in the tool topology page set the diameter to the smallest diameter of your formtool (Ø19.7 in the example given). This works for the D offset.
    For the H offset I am afraid that the programmer will have to remember to set the depth correctly when defining the job.
    Jun 2009
    10
    The tool diameter will work for diameter if tool is set up as a mill.
    We use tool message to set our tool offsets when we set up a tool and have the following code in our .gpp file to load those offsets in the start of our output file.
    @def_tool
    {nl, ' (TOOL ', tool_number, ' = ', tool_message, ')'}
    {nb, 'G10 L10 P', tool_number, ' R', msg_mill_tool1}
    endp
    GDG
  1. Custom Form tools in MCX / Mill ?
    By Scott_M in forum Mastercam
    Last Post: 08-21-2009, 02:59 AM
  2. Setting up Tools - OKUMA OSP700L
    By hiatec in forum Okuma
    Last Post: 03-19-2008, 12:51 AM
  3. Setting tools on my KMB-1
    By mmachining in forum HURCO
    Last Post: 12-07-2007, 10:27 PM
  4. Replies: 0
    Last Post: 11-09-2007, 11:25 PM
  5. Setting tools
    By Drew in forum CamSoft Products
    Last Post: 11-25-2006, 05:45 PM
