Can not get the servo motor to turn fast or reverse direction
Amp is a Mitsubishi MR-J2S-40A and HC-KFS motors
Not sure about Mitsi servo amps but it sounds like it may be a simple port / pin problem. Double check your ports and pins setting in your interface software and that the wires are correctly attached. I beat my head against a wall for day until I realized I had inverted the pin numbers for step and direction.
Good luck.
Warren
Did check the wires for the step and dir, even switched them and still the motor moves slowwwww and the direction changed but always moves in the same direction for + and - moves
Would I need to do something with the encoder setting in encoder/mpg?
What is the encoder pulse count/rev?
First you get good, then you get fast. Then grouchiness sets in.
And what is your steps/unit set at?
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
Do you mean in Mach3 or in the Servo
Mach3 step/unit, and servo encoder count.
Gerry
Mach3 steps are 2000 and servo end coder count is131,072
That was what I figured. The Mits encoder is extremely high in counts, and so far as Mach is concerned, a pulse is a pulse, so one step out is going to be enough to cause one encoder count. Mach can only output a relatively low pulse per second rate due to the parallel port hardware, as I understand it. So I think that is why you're only getting slow motion, even at maximum step rate.
I think you'll need to go with a much less precise encoder in order to get more speed out of your system, something on the order of a 500 to 2000 line encoder, depending on whether you can use the signal in quadrature mode or not.
First you don't need a different incoder, you need to set up electronic gearing to work with mach. The interface voltages are not the same for the drives and 5v breakout boards. There is a lot to explain... feel free to give me a call (east coast) Erik 215 880 6385.
The drives work fine on 5v signals, you just have to read the manual right. There is an error in the manual.
Like said above the slowness is caused by the pulse count of the encoder/drive. Use Parameter 3 to divide the counts necessary to move a given distance. If parameter 3 is set to 10 then the steps per rev is divided by 10 so you have 13,107.2 steps per turn.
Parameter 21 needs to be set to 0001 for step/dir input. It defaults to 0000 which is CW/CCW input.
These Mitsubishi drive and motor sets are great. I have a few more laying around for some more projects. 2x 1kw, 1.5kw, 2kw, 3.5kw, and a 5kw.
I've got 4 J2S-40A drives and have the manual. Where exactly is the error? Which pin is step and which one is direction?
Can anyone post the wiring diagram for interfacing mach3 with Mitsubishi MR 40 drives. I have connected and tried and tested in as many ways I can. Help me rectify this problem.
@macona Sir, can you help me how to wire the Mitsubishi servo motors with mach3? I have given the step and direction signals to the drives for pins 23 and 25 on the drive as they are the step and dir pins. And applied 24V DC to the OPC pin.Connected the SG pin the mach bob ground. Set the parameter 21 to 0011 and 0001. But it didnt work.
