Hi
I am a newbie in working with CNC equipment.
Ï have a small lathe i converted to be controlled by CNC.
How do i get the Mach3 Turn to do multiple passes when turning.
Børge
Hi
Børge
Maybe i explained it wrong ?
Is it called Rough Turning cycle...
Børge
Hi
With MachScreen you must create a button "Multipass" and select execute basic-script here the script
(Rem Context 10002
repeats = Question ("How many iterations?")
depth = Question ("Maximum depth in first pass?")
perpass = Question ("Amount to drop on each pass?")
SetOEMDro 80, depth
SetOEMDro 78, repeats
SetOEMDro 79, perpass
DoOEMButton 218
Message "Press Cycle/Start to Begin")
you must create and other Visus "repetition number" code oem 78
and a second Visus "Z increment" code oem 79
and a third Visus " Z limits" code oem 80
tats all
good lock
Serge
