Here is what i would like to do. Let me know if this is possable.
Id like be able to put a tool in. Tell the machine to start the program. And then have it automaticly move over to a vertical mounted limit switch. Have it come down and touch off. Automaticly setting the tool lenght. Do the first operation and then pause. Then i would change the tool. Then i would want it to go back to tool setting and reset the lenght and do the next operation.
Is this possable on mach?
As the tool setter im planning on verticaly mounting a limit switch. i know this is not the most accuate way but its close enough for the stuff i do.
