603,365 active members*
4,130 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > setting z depth of cut V25 3 axis pro
    Dec 2012
    22
    I want to machine both sides of my stock, have set up both side origins but when I set a tool path it goes to the total depth of the stock. I set a predefined depth but the simulation again goes to the total stock depth.
    Mar 2012
    1570
    How did you set your depth, what tool path feature are you using? Can you post your file?
    My guess is either you don t have your top of part set correctly or you haven't set the depth correctly.
    If you are doing a 3d tool path you will have the option to set what z position to start cutting and stop cutting based on your model.
    For 2d paths you have your top of part setting and your depth of cut.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
  1. Curve 5-Axis depth of cut
    By coykiesaol in forum Mastercam
    Last Post: 12-21-2010, 10:23 AM
  2. Problem setting the depth of engraving
    By mtrobregado in forum Commercial CNC Wood Routers
    Last Post: 01-15-2010, 01:59 PM
  3. Z depth setting in pcb-gcode
    By Drools in forum PCB milling
    Last Post: 11-26-2009, 10:34 AM
  4. Depth setting rings
    By mgamber in forum Uncategorised MetalWorking Machines
    Last Post: 11-04-2005, 03:37 AM
  5. Setting cutting depth
    By awemawson in forum FeatureCAM CAD/CAM
    Last Post: 10-30-2005, 10:05 AM
