Hi i have a version 4.1 of hobby cnc and my motor are 1.67V , 6.8A
don't worry my card has the heat sink
anyways my probleme is power ON the motor and i try to make it turn
it doesn't move at all. My wiring is good it over check it. i good the good voltage at con 18, 35, etc.....
I can no turn the motor by hand so the field inside has current and i hear a little noise that sounds good .
it think it my be a problem btw the computer and the hobbycnc card (maybe the setup commincation...) i only have 1 printer port so it should be LTP1.
All so it doesn't detect my firnware of the hobbycnc..
do i have to do something with the limit switch (X1,X2 ,Y1,Y2,Z1,Z2)????
or the Leds section???
can someone help ??
