587,132 active members*
3,104 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > SFM capability of Tialn
Results 1 to 4 of 4
    Sep 2006
    296
    What surface speeds is everyone running on tialn coated mills? Not much info to find on the net that i can find as far as the SFM. Getting into high speed milling. I know it has alot to do with metal type and hardness but just in general whats working for you.
    I am currently milling around 600SFM with a pretty heavy chipload and getting about 30 minutes of cutting time from carbide inserts tialn coated. Id like to know where the speed limit is before tool life generally starts falling off fast.
    Dec 2013
    14
    Re: SFM capability of Tialn
    Are u using coolant
    Sent from my SM-T337V using Tapatalk
    ragingswaging.com
    Sep 2006
    296
    No. When i tried coolant it thermal shocked the inserts and tool life fell off rapidly.
    Jun 2010
    4256
    Ask the vendor.
    Cheers
    Roger
  1. Tialn coated carbide vs non
    By GITRDUN in forum MetalWork Discussion
    Last Post: 08-12-2015, 05:08 PM
  2. Carbide Variable Helix End Mills 5 & 6 Flute Tialn Coated
    By CDTooling in forum News Announcements
    Last Post: 09-01-2010, 11:55 AM
  3. TIalN 1/4" ballmills??? where to buy?
    By mc-motorsports in forum CNC Tooling
    Last Post: 05-07-2010, 05:32 AM
  4. Tialn coated vs. uncoated?
    By Driftwood in forum MetalWork Discussion
    Last Post: 01-05-2009, 02:57 AM
