I have a 16mm motor shaft about 35mm long that I need to couple to a another shaft 18mm in diameter but it has been milled flat on both sides to make the shape you see in the pictures. It is 8mm wide, 6mm deep down the shaft and there is an area of about 1mm of true round shaft that could be used if need be, otherwise all there is the flat um, 'thing' to grip to.
The motor is a 1.8Kw 5000rpm BLDC that will couple to this ER32 live tool for a DIY metal milling CNC machine, no numbers but a fair amount of torque involved - its will be servo driven and will be expected to be able to reverse with no backlash for work like rigid tapping and so on...
How would you design and make a coupling here ?
At present I have no lathe, but I do have a mill with an ER40 26~25mm collet in which I can make a kind of home-brew lathe if need be (and some steel rod of the same dimension, but maybe this is too small) - also a boring head will arrive in the mail shortly... A slitting saw of unknown width and radius, but I'm pretty sure sub 1mm and sub 100mm is available on loan also.
Maybe this is a job for a real machinist ? in any case, how would you design it ?
What are the considerations/implications involved ?
Many motor couplings have rubber inserts or helical spring sections to account for the slop and concentricity issues in installation. What I was going to build was very rigid, but the flip side of that is that I need the alignment to be spot on...
Any help appreciated!
Kind Regards,
Nick Mulder
