Anyone have a dxf file of an elk or moose for cutting on plasma?
No, it's stained solid oak 3/4" "scrap" I pulled out of the firewood bin I got from a co-worker. He refuses to sand and re-stain so he tears out whatever he re-does and uses new wood. He brings me a bin or two when he's full. Mostly hardwood scraps from his cabinetmaking side job. He's super talented at cabinets. I usually burn it up at the lake but thought these would be perfect for experimenting on. I keep trying to convince him to make a CNC so he's going to make a CNC Mortiser. He got a start on it and all these high paying side jobs keep coming in so what's a guy to do?
Ferny.
cnc_newby,
This art may need a little work however it might be a good starting point,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Dragon Head Vector
Long Dragon Vector
[plasma/router]
Free DXF - vectorink.com
Hey that looks great. I will send pick of finished part. Thanks alot....
wow this thread is incredible
My Plasma Project Hyper-therm 260A on a FPB 1800. Wedding one thx to "Jalessi" for the Conversion.
Any chance you guys have that Browning Deer symbol that everyone around here has a sticker of on there trucks?.... or maybe this one?...
A friend is leaving work for another job soon and want to make him one of these as a paperweight! :-)
Perfect!... Thank you very much!
my question are how can i polish the image after i trace with Inkscrape. cause everytime i did it it turn out too have tooo many nodes point. and when you click on the the picture after trace there are like millions of nodes how can i minimize those node. thank you
P.S can someone help convert that into vector base graphic plz thx. i can't seem to get it to work my knowledge isn't that good in inkscape or converting. Thank you again
I need a good mother's day gift ! Anyone got any ideas ?!?
Anybody got 1911 hand grip files, that would be sweet, but it doesn't seam like there is a lot out there.
i'm trying to make one of this for my daughter !! could someone help me !
do you have a better picture of this? The image is so small it is too blurred when zoomed to get a good trace. I assume you just need the numbered ring in the picture?
Regards,
Wes
Hello,
This image is not one that is very easily traced, or at least not traced so it will look like the picture. The automatic trace features normally leave too many unusable vectors along the traced features and the overall look is too busy to use for vector and toolpaths. I do not use Inksacape so I can not help with that but I have tried to do a manual trace of the basic features of the dog and then go back in and add some of the curves for the hair characteristics. Here is what I have so far, and I don't like the outcome but I figured maybe you can edit it to your liking and possibly use it. It really does not do the dog justice and I am not an artist so I'm sorry if it is less than you expected. Maybe it will help somehow and if not just delete it.
Regards,
Wes
i have a better picture however it's too large to post ! Actually i'm looking to make the whole thing ! i'm going to cut it out of flat plate and bend it where it needs to be bent ! Going to use a laser to cut the plate....
Can you create a .zip file to compress it and get it to fit the site limits? If not you can send it to my email and I will see if I can get a .dxf of it done. Only thing is if it is bent then I would need the sizes of the flanges etc. and the K factor you will use to bend it.
If you don't know the K factor at least let me know the material thickness and I will use one from my shop chart. Actually any and all dimensions you can supply will greatly help me get the scale set to the right size. email: wes dot spence at comcast dot net
Regards,
Wes
