can someone convert this to dxf..thanks
Hi guys I'm new to cnczone. There are tons of files on here. Thanks to all who have donated. I'm looking for a couple dxf files for a laser. Hoping someone can help me find a fire engine and a c130 hercules. I will be cutting them out of stainless most likely, so any help with these dxfs would be greatly appreciated! Thanks in advance!
Here is a link to all of the attachments in this forum. I as sure you can find what you need here. I have bookmarked the linked. Always use it.
Attachments - CNCzone.com-The Largest Machinist Community on the net!
farmertom
Here you are, made it once before.
The other picture is to small to get anything out of, need a bigger one.
You can also search her in the section of attachment
CNC 6040 Router Engraver
Mack 3
Here is the other one, not perfect, the picture is to small, but you can "tweak" it a little so you get it ok I hope.
Mack 3
Here you have a few or you search for "stencil fonts" hope it helps.
Mack 3
About a year ago I picked put these and found some of them useful. With little or no clean up needed, not bad for $20.00. http://plasmaspider.com/shop/detail_font.html
Hi Lurker, I have just procured the full version of Vcarve, I will have a looik using the full version and let you know/post it.
Eric
looking for the outline of the state of wisconsin and the USA.
thanks to anyone that has it
Hello,
Here is the complete USA .dxf file and it has individual vectors for each state so you should be able to get Wisconsin no problem.
Regards,
Wes
