OOOOOOH RAAAAHHHHH
Safe machining
Hell All,
Looking for DXF file of dice in picture to laser cut and hand bend. Thanks in advance.
Hector
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Made 2 today at work. Adjusted program to 25% (1.5" sides) of original.
Left one is 16ga sst and right one is .032 alum.
Might try smaller tomorrow.
Attachment 259562
Smaller dice program
1.5" side and smaller version.
Attachment 259564
I scaled as well to have each side be 1" and cleaned up circles and radius since they have multiple entities. I also made tabs longer to have only .040" material on each side to make it easier to bend. I'll cut some next time I head to Chicago on the Bystronic Laser.
By the way your dice look great!
Hector
Thanks!!
looking for a foot print more of a shoe print. and anything running related. i plan to make a logo using the foot print of a shoe, looking for something to start with or idea
thanks
You'll need to make sure you don't use anything someone can later claim is a copy righted image. Or sufficiently alter an existing one to make a new and unique version that's different enough from the original no-one can complain.
It would be a major pain to have to sort out licensing issues down the track after you've done all the hard work to create a business.
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
There are MANY sites that you can get ideas or files you can use for what you want. Here is but one example - - - feet image search at WPCLipart.com
The license for this page reads like this - -
Allowed Usage Summary:
•You CAN modify any of the images in any way you wish.
•You CAN use the images in your own work, both personal and commercial.
•You CAN use the images, altered or not, for any printed work.
•You CAN use one or several of the images on websites
(for school, personal or even commercial use... see below.)
•You SHOULD NOT redistribute (as a collection) a lot of the images online.
Just check on the site that you find what you are looking for and see if you are allowed to use there files in the way you want to. On some sites you must pay a fee to use there art work and others du do not! CHECK THE LICENSE!!!
OR you could pay to have an original picture made just for you and skip ALL the hassle. There are many places that do graphic design and for a few dollars you can get a one of a kind piece of art! Check out the local high schools art class also!
Larry
Good luck on your business!
Does anyone have a 2d DXF of a wile boar profile?
Hi guys! We are doing a Nightmare Before Christmas themed Christmas tree this year, and I thought I saw someone post some Nightmare Before Christmas DXF files on here before but can not seem to find them. Do you guys have any Nightmare Before Christmas files I can use to cut some ornaments? Thank you so much!!!
Hopefully it helps. Only for private use, not for resale.
