never heard of that before but will google it later. the stainlesswas a scrap sheet of 1/8" and was 18" in dia.
Check THIS for some patina information.
Thanks for the material information.![]()
Isn't it just oxidation? It happens on most metals when heated.
what was my original thought, as the colouring can be wiped off the surface unless it is lacquered first, anymore ideas people?
Here is some more info.
http://www.sculptnouveau.com/hotcoldinfo.html
Here is kind of a basic silhouette of a pine tree. Here you go Ericandmollie.
No matter how many times I draw a thunder bolt it doesn't look right. Any takers out here?
What is possible? What you will!
Here is one for you motorcycle guys.....laser or plasma cut
There are some HERE.
Your avatar looks quite nice.![]()
New DXF File ---> Thunderbolt
Free DXF - vectorink.com
New DXF File ---> Thunderbolt 2
New DXF File ---> Thunderbolt 3
I've added a RSS widget to my blog.
If anyone has a website or blog that wants to add all the latest DXF Downloads, from www.mydxf.blogspot.com
It's very simple to add the widget to your site/blog, just click the "Get Widget" button at the bottom of the widget on my blog (right sidebar), then follow the link to get the code. You can change the look & size to fit your own site/blog ( http://www.widgetbox.com/widget/free-cnc-dxf-files ).
Once you place the code on your site/blog, that's all you need to do, everytime I post a new DXF File on my blog the widget should automatically update.
New DXF File ---> Pig 1
New DXF File ---> Rooster 1
New DXF File ---> Horse 5
[quote=RayinNH;438736]Sorry for the delay replying, working overtime and gots to keep hobby projects moving of course.
How much do you know about Autocad? I tried the offset trick and autocad wouldn't let me offset a polyline. I have a different file I am trying to do the same thing on now, and I had to explode the letters and offset each (of many) entities. Very time consuming, any ideas?
I am still getting compliments on the project for the church. Thanks again.
[quote=gravy;447806]AutoCAD can be picky at times when using offsets, especially when the offset will intersect itself. If your dealing with closed shapes, try using pedit to close the polyline if it's not allready. Also, zoom in very close to pick a more accurate offset location, If not zoomed in close enough, AutoCAD can get confused by the location you pick.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
New DXF File ---> Ship
