586,061 active members*
4,702 visitors online*
Results 1 to 4 of 4
    May 2019
    7
    Sharing my touch plate mod
    This has probably been done before but this is a simple mod that I did to the touch plate magnet. The wire kept breaking at the lug joint so this prevents this from happening by adding the wood handle so that no force it put on the wire when removing the magnet from the cutter.
    Mar 2011
    61
    Re: Sharing my touch plate mod
    Neat idea, though I just permanently attached the wire to a metal component and just zero it the usual way.
    Apr 2004
    326
    Neat Idea. But a little rough on implementing. I'm going to model a 3d printed solution with a nice thumb tab to do similar, if you don't mind.
    (PS. I've already repaired my broken wire once, getting close again now).
    Feb 2005
    829
    I just grounded my metal frame to my cnc controls, no wire needed to connect to the spindle.
  1. Little help for touch plate
    By abeekaushik in forum Open Source Controller Boards
    Last Post: 06-10-2018, 09:39 AM
  2. Touch Plate
    By gishere in forum LinuxCNC (formerly EMC2)
    Last Post: 03-01-2014, 01:50 PM
  3. Replies: 14
    Last Post: 02-11-2014, 02:56 AM
  4. CNC Touch Off Plate
    By bgriggs in forum DIY CNC Router Table Machines
    Last Post: 01-04-2014, 05:48 AM
  5. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
