587,354 active members*
4,259 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Sheet metal forming on a CNC mill...
Page 1 of 2 12
Results 1 to 20 of 21
    May 2005
    2502
    Can someone tell me more about what's being shown here:
    http://www.youtube.com/watch?v=GxysBla3NyI
    Looks really cool. Seems like that sheet metal has to be moving down in Z each trip around or a forming piece underneath is moving up somehow.
    The sheet metal appears to be gripped in a frame that's riding on some kind of linear shaft system?
    Best,
    BW
    Jul 2005
    12177
    Inside out Metal Spinning .
    Have you ever seen Metal Spinning done on a lathe? This seems just the same but kind of inverted; tool spins and moves around and work is stationary. I guess the purpose of spinning the tool rather than just moving a stationary tool around could be threefold; first the spindle bearing can handle a much larger load safely when spinning, second the friction may heat and anneal the copper in the region of contact preventing work hardening and three many CNC mills will not run the axes under feed unless the spindle is turning.
    I would expect there is a form under the shape that is being generated and the corner supports for the copper sheet could simply be spring loaded so as the tool works the copper down over the form the supports pull the surrounding area down also.
    I have to thank you for the link because I intend to get into this type of work. Have you ever seen the embossed copper ceilings and wall panels in fancy offices and restaurants? These are expensive. A couple of years ago I bought a Haas GR510 with the intent of developing a retirement business doing large embossed copper panels. My idea was to have the sheets of thin copper held down by vacuum on low density MDF and then use a program something like Photo Vcarve but instead of cutting just deform the copper; hoping the soft MDF would just crush out of the way. I would only be deforming a few hundred thou deep so I thought this seemed reasonable to expect.
    So far this project is just a gleam in my eye; the GR machine spends a lot of its time doing routine production for my existing business and I have spent most of my time during the past two years on new product development for my existing companies. Ah, futile dreams of retirement.
    Jan 2004
    3154
    Geof
    Try red Urethane instead of the MDF
    www.integratedmechanical.ca
    Jul 2005
    12177
    Quote Originally Posted by DareBee View Post
    Geof
    But the urethane is non-porous and an elastomer, correct?
    I could not suck a vacuum through the urethane to hold the sheet down and it would rebound after the tool has passed even if I could suck it down. I want the metal deformed down into the MDF to stay down.
    Sorry for the hijack Bob; when (if) I get this project off the ground you can send me a picture to process into a plaque you can put on your wall...machine time gratis if you pay the material cost.
    May 2005
    2502
    I was able to discover a bit more after looking through Google. This is a relatively new process called Asymmetric Sheet Incremental Forming (ASIF). The "Asymmetric" clues you to a fourth advantage which is the ability to do things that aren't symmetrical in the way they'd have to be with a lathe.
    It appears the form underneath does rise up or the sheet can come down either way. I could envision driving leadscrews as a 4th axis to move the sheet/form.
    One other thing I learned in my web prowling is that this technique does not involve a die. It's hard to find info--apparently its a very new technique. You have to buy mechanical engineering research papers to learn much.
    Best,
    BW
    Jul 2005
    12177
    The shape was very deep so I think progressive dies would be needed. Also it is quite possible the form could simply be a rigid plastic because it is taking very little if any load. I suspect the form is largely responsible for holding back the already formed material from moving deforming further; the tool is stretching and deforming to match the form but the form is not really contributing to the shape in the region it is being made. Metal spinning uses a similar technique in that the metal is deformed down onto a form while regions that are yet to be spun are held and stabilized against a movable spinning disc equivalent to the moving supports.
    Even though the process is slow the overall cost of producing just a few examples could be considerably cheaper than pressing if all that is needed is a low cost plastic plug.
    Thinking a bit further I realise you could machine the plug and then use the same program for doing the forming. The tool used for machining would need a nose radius larger than the forming ball by an amount equal to the thickness of the metal being formed. It may also be possible to get an acceptable smooth finish on the formed part even using a plug that was made with a large stepover because the part shape could come primarily from the forming tool action rather than closely replicating the plug.
    Jan 2004
    3154
    Hijack some more.
    Geof
    I here what you are saying about the vacuum - I agree.
    As for as deformation goes red urethane is great. We use it all the time for embossing into. It is flexible enough to give and it is stiff enough to form really well and you can do it for a million hits without needing replacement.
    Jul 2005
    12177
    Quote Originally Posted by BobWarfield View Post
    ..It appears the form underneath does rise up or the sheet can come down either way. I could envision driving leadscrews as a 4th axis to move the sheet/form.
    One other thing I learned in my web prowling is that this technique does not involve a die. It's hard to find info--apparently its a very new technique. You have to buy mechanical engineering research papers to learn much...Best,
    BW
    It may be possible to do the sheet moving down fairly easily by having a mechanical link to the head. The flat surface of the sheet stays in more or less the same place relative to the tool.
    Regarding it being a new technique I would mildy disagree, not with you Bob but any engineer making this claim. It is an old technique being performed with a new assembly of tools. Surely you have seen beaten copper and bronze bowls in all manner of shapes with intricate decoration in museums. These were done on a wool packed leather form or against a block of lead with different shaped punches and a whole lot of skill. And they were done several thousand years ago.
    May 2005
    2502
    Quote Originally Posted by Geof View Post
    I thought of having some sort of support underneath tracking the head. It's an interesting thought, though potentially awkward to implement. There are some pictures that show a sort of probe underneath that tracks the head. It reminded me of an English wheel that can move in XYZ.
    Regarding your red urethane, it seems like an ideal material would deform right under the probe, but would resist deformation extremely well away from the probe, and would spring back after the probe moves on. This sort of thing could underlay the sheet metal and while the whole assembly moves downward, the tool could spiral out as the video shows. Is this what you're thinking of with the urethane?
    A lot of the pictures I see on the web have the head pushing down so part forms downward rather than pushing the sheet down as the video does.
    All of this seems to imply that some kind of support is needed when you are leaving enough sheet metal hanging that pressure in the middle is overly deforming the areas that are not supported but are sufficiently far away from the probe.
    Geof, I can't see that as a valid comparison. May as well say CNC is not really anything new because manual lathes work on essentially the same principles as a CNC lathe. If you generalize, that's true, but it isn't a useful comparison. In this case, it is a new technique relative to manufacturing techniques available in the past. This is a plastic deforming process, but there are an awful lot of them, and it seems to me this one has a lot of novel features.
    Since reading this, my favorite thought has been the "Boyd Coddington" CNC machine. Imagine a big gantry machine that can do this. You feed it a CAD model of a new body panel and it shapes the panel out of aluminum. Imagine the potential for one-off cars like Boyd's hot rods and the like. The custom car guys would go crazy for it. In that respect, it really does get to be a CNC English wheel.
    I think if one wants to pursue this, it would pay to purchase 3 or 4 of those research papers you find under Google. I could find very little else about this technique. What little I could read was clear you didn't need a die specific to the part being made.
    Best,
    BW
    Mar 2007
    5
    copper ceilings
    Inside out Metal SpHave you ever seen the embossed copper ceilings and wall panels in fancy offices and restaurants? These are expensive. A couple of years ago I bought a Haas GR510 with the intent of developing a retirement business doing large embossed copper panels. My idea was to have the sheets of thin copper held down by vacuum on low density MDF and then use a program something like Photo Vcarve but instead of cutting just deform the copper; hoping the soft MDF would just crush out of the way. I would only be deforming a few hundred thou deep so I thought this seemed reasonable to expect.
    Geoff,
    if you machine can handle that size why not cut into the MDF, suck the copper down and then explosively hydro form into it? you might even get more than one go with the MDF
    Jerry
    Jul 2005
    12177
    ...Regarding your red urethane, it seems like an ideal material would deform right under the probe, but would resist deformation extremely well away from the probe, and would spring back after the probe moves on.......
    The urethane was mentioned by Darebee in the context of my plans for CNC embossing large sheets. For this my expectation is that the spring back would be undesirable; I want to deform the metal down immediately at the probe but not spring back. This is why I think I will need a material that is both porous, for the vacuum hold down, and crushable underneath so the embossed parts do not come back up and in doing so lift the surrounding unembossed sheet.
    Regarding my 'not a new technique' claim it depends which side of a potential patent dispute one could be on. The side that claims it is new and unique or the side that claims it is an obvious extension of prior art.
    Jul 2005
    12177
    Quote Originally Posted by jerryrig View Post
    Geoff,
    Jerry
    Explosively hydroforming over an area 5 feet by 10 feet boggles my mind even if it doesn't boggle anyone elses mind. That is the area I can and hope to handle.
    I did think of explosive hydroforming when I viewed the video. I think it can produce items comparable to what was shown in the video. But it requires a fairly complex setup.
    Sep 2005
    1660
    Often my comment is, "there's only one way to find out", however this does NOT apply when it comes to explosive forming. I've never done it, nor even seen it done.. but in my mind... hydroforming should be able to do the job.. just forget about the explosive part..
    Jerry
    JerryFlyGuy
    The more I know... the more I realize I don't
    Jul 2005
    12177
    Quote Originally Posted by JerryFlyGuy View Post
    Jerry
    No not really, the two techniques are very different. Hydroforming is just sheer brute force; water at thousands of pounds per square inch pressure distort the material into a very large and strong surrounding die. Or that is my understanding of it; you need heavy tool and big high pressure pumps.
    Explosive hydroforming is quite simple; your die, which can be made out of gypsum plaster is at the bottom of a tank, your material is above it and the tank is filled with water. There is a membrane or something between the die and the material so this space is filled with air not water. An explosive charge is detonated in the water and the shock wave drives the material against the die very fast. So fast that even though the die is very weak and friable its inertia stops it moving fast enough to get out of the way so the material is formed around it.
    You do need a fairly sturdy tank but nothing horrendous; the amount of energy released in the explosion is not that great and the explosion is surrounded by water on all sides. In addition it is possible to have a self contained system in which the explosive material is a Hydrogen/Oxygen mix obtained by electrolysing water.
    At least that is my understanding of it.
    Sep 2005
    1660
    niffty.. I learned something new today... Do ya got a fish tank to do some trial's w/? I'd suspect that the removal of the fish is required before dropping the depth charge into the tank
    Jerry [long time no chat..]
    JerryFlyGuy
    Jan 2004
    3154
    If we are trying to make embossed sheet material (such as ceiling tiles) a good way to make product is to rollform between a positive and negative synchronized roller set.
    No good for one-offs though.
  17. #17
    Apr 2003
    170
    This is a very interesting process.
    From what I’ve been able to find on ASIF web searches, “spring-back” does seem to be a concern. But I think the comparison to sheet forming with an English wheel and sheet plastic vacuum forming seems close.
    It appears that the sheet is suspended within a frame that restricts movement to just vertical, and the “form” is a simple “starting point” to begin the process. With a rotating tool and down pressure generating heat to form the material as the tool travels around the geometry. The frame seems to be able to travel freely downward, guided by the 4 posts. Apparently, getting the “forming” temperature correct is the challenge. I would think trying this process with a thermal forming plastic sheet would be a easy test before moving to metals.
  18. #18
    May 2005
    2502
    I love the idea of this process, but it will have to wait until I get a bigger machine to play with it. Hopefully there will be more information available by then as well. Seems to be kind of a closely guarded secret at the moment.
    Best,
    BW
  19. #19
    Oct 2008
    Metal Forming
    I found one process for metal forming with example.
    Here is the process steps and corresponding image
    1. Completely spun - Ends formed using this technique are spun over a tool, which has both the spherical and the knuckle radii. This allows the end to be formed entirely on one spinning machine.
    2. Press and Flanging - A contract specific spherical radius is formed using specialist hydraulic Boldrini presses. Following this the required knuckle radius is spun using Boldrini flanging units.
    3.Spin and flanging - Unlike pressing, the spherical radius is formed by spinning the plate blank against a fixed forming tool. Forming of the knuckle radius is made in the same way as pressed ends.
    Metal Forming
    http://www.purdiedishedends.com/index.html
  20. #20
    its good ...................... we also provide same service .....................
    www.dished-ends.com | www.icemcladplate.com | www.louver.in | www.icemgroup.com
Page 1 of 2 12
  1. Sheet Metal Patterns
    By phatfred8 in forum Solidworks
    Last Post: 05-21-2009, 08:34 PM
  2. Bit recommendation for sheet metal
    By adda in forum Uncategorised MetalWorking Machines
    Last Post: 01-26-2007, 08:50 PM
  3. Tog Gun Construction From Sheet Metal
    By username132 in forum European Club House
    Last Post: 01-15-2007, 02:11 PM
  4. RFQ for Sheet Metal Work
    By Rob_M. in forum Employment Opportunity
    Last Post: 02-13-2006, 08:14 PM
  5. Thin sheet metal
    By itsme in forum Welding Brazing Soldering Sealing
    Last Post: 03-01-2005, 10:24 PM
