I'm looking for a small/light mill and maybe lathe for plastic/brass/aluminum work, mostly for modifying Remote Control cars. I would use it in my apartment (so it can't be big or noisy). How loud is a sherline mill and lathe when machining plastic/brass/aluminum compared to using a dremel on these materials?
Basically I want to get something more accurate instead of using a dremel or drill by hand. Some of the material will be hard but if a dremel could do it a sherline mill could, right?
