587,925 active members*
3,781 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Shizuoka AN-S data dump and gib question
    Aug 2012
    Here's a complete scan of the owner's packet from my AN-S. I figured this is a slightly different model from Yeltrow's, so this could be useful for folks who have the imperial version. Most pages appear to be photocopied instead of mimeographed, so it's a little more readable too. Enjoy!
    https://drive.google.com/open?id=1BB...YE_hoQ3vNL3h6I
    So the question - I noticed that there's quite a bit of play in the Y-axis of my machine and it looks like it needs a gib adjustment. Has anyone performed this operation on an AN-S or similar machine with box ways?
    Thanks all,
    ~Josh
    Re: Shizuoka AN-S data dump and gib question
    Hi Josh - thanks for posting your manual. The Yeltrow manual was actually mine and it's actually a pretty faithful image of what I have. The fact is that my manual is in a pretty poor state, so I've downloaded yours as a much more readable document!
    Yes, I adjusted the gibs on the Y axis. It was pretty tricky, as you need to be able to determine when the gibs are biting and then back off. Given that there are 3(?) of them on the Y axis, it's quite a job, especially when you can't disconnect the ballscrew and move the table by hand. Removing the belt and turning the ballscrew by hand was the best I could do but a load meter on the servo drive might have been a neater way to indicate the drag on the axis.
    Your post is 2 years ago - did you manage it in the end?
  1. Replies: 3
    Last Post: 01-06-2020, 07:22 PM
  2. shizuoka power supply question
    By drhanger in forum CNC Machine Related Electronics
    Last Post: 03-13-2016, 02:44 AM
  3. Tool data Question
    By LockTech in forum BobCad-Cam
    Last Post: 02-22-2011, 12:57 PM
  4. Dump question for Probotix users and g-code
    By unlv-soa in forum G-Code Programing
    Last Post: 04-24-2009, 11:45 PM
  5. Data server question
    By npinto in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-09-2007, 10:47 PM
