Hi i have the opportunity to get a late 70's AN-S CNC. It has a dufunc Bandit controller with missing boards - as the repair person took the boards to fix and never returned - end of using it.
Allegedly mechanical condition is good but i can't verify as its not under power. It was owned by a sheetmetal shop that used it 10 xs since 1997 and previously by a tool
Plan is to get this and retrofit with Gecko drives, mainboard, power supply and run off of PC.
Being completely new to cnc machining and machines, and this will be my hobbiest CNC machine, do you think it is worth the endeaver? I can get it for $600 + $200 cost to trailer it back myself and i figure it may cost $1200 to retrofit if i can not use the existing servos /encoders. But i would hope i can use the existing servos but not sure exactly what they are. This assumes the machine is fine mechanically. Is there any thing i can verify mechanically while not under power?
Thanks in advance,
Paul
