588,116 active members*
4,832 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > shopbot tools with gecko 340
Results 1 to 6 of 6
Hybrid View
    Feb 2005
    74
    i am using a microcontroller Shopbot tools, to send step and direction to the gecko g 340.i have good speed and control but in one direction only. the step pin measures 3.3 volt with the multimeter. the direction pin measures 5.5v one direction and when attempting to reverse , the measurement
    is 3.3v.is the voltage too high to create reversing, if so what remedy ,pull up, pull down resistor ?
    Dec 2004
    518
    I think you are on the right track
    Doesn't sound like your direction line is putting out a solid "low" signal. Here is a link that might help: TTL/CMOS Levels.
    A real quick thing to try would be to disconnect the direction line and tie the input on the Gecko directly to ground. It should then reverse, verifying your theory.
    Good luck. (wedge)
    Feb 2005
    74
    evodyne , thank you for the reply. yes , the direction reverses when the direction lead is disconnected.
    Dec 2004
    518
    Next Step
    I guess I'd be inclined to try a pulldown resistor from the direction input to ground-something on the order of 5K (for 1mA) as an initial try. Use your VOM to see what you have with it in place and adjust as necessary. I probably wouldn't go much below 1K (5mA) without checking to see what the output is rated for-don't want to let any smoke out, right? Good luck!
    Feb 2005
    74
    problem solved, works great. had 1k resistor from the controller to the gecko. thank you for the help.
    Dec 2004
    518
    Glad to hear you are up and running. Seems to me that you were on the right track from the beginning-good troubleshooting skills! Happy motoring.
  1. Tools advice needed for start
    By pigifly in forum Uncategorised MetalWorking Machines
    Last Post: 12-10-2009, 10:18 PM
  2. shopbot tools controller
    By najnielkp in forum DIY CNC Router Table Machines
    Last Post: 02-09-2005, 08:42 PM
  3. Gecko vs Rutex
    By samualt in forum Gecko Drives
    Last Post: 10-21-2004, 07:48 AM
  4. Servos or Steppers..... and other gecko related questions
    By UKRobotics in forum Gecko Drives
    Last Post: 04-19-2004, 08:14 PM
  5. To Gecko, or not to Gecko...that is the question!
    Last Post: 09-23-2003, 02:42 AM
