588,385 active members*
5,481 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > Shopmaster start/stop button died
Results 1 to 6 of 6
    May 2006
    16
    The start/stop buttons on my 2003 Bridgemill have both fallen apart.
    I use the lathe on a production job that requires me to use the start/stop button alot. I wore out the lathe button, switched it out with the mill button
    and have now worn it out. Wondering if anyone has "upgraded" to another type of start/stop switch?
    David.
    Dec 2007
    413
    On the machine our unit had, we did a lot of milling, and found that the contact points on the forward side got pitted- we switched them out with the points for the reverse side which were seldom used. We used the hi-low spindle brake on the lathe, so the switch was only used a few times per day. You could always change them out for a drum type switch, but that might be costly and require some knowledge of wiring. Otherwise just buy a couple new ones from shoptask and figure to get another 5 years use.
    Nov 2007
    277
    Grainger sells drum switches at a good price.
    Jan 2008
    458
    My original shoptask was equipped with rotary style switches, which began to get loose after about 6-7 years. I considered upgrading to the push buttons, but it required cutting 2 rectangular holes in the sheet metal. Eventually I found a couple of 3 pole double throw toggle switches at the surplus center for 5.00 each and they fit in the original switch holes.
    May 2006
    16
    Thanks for the suggestions.
    David
    Dec 2005
    183
    i have two sets of start/stop/reverse buttons sitting around. They are about 98% new. I switched them out for allen bradleys and contactors when I did my VFD upgrade.
    I'll part with them for 15 bucks for one and 25 for two. I'll pay USPS shipping.
    Normally I would give them away but I've been hitting the credit card pretty hard lately.
  1. E-Stop Button
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 05-19-2008, 08:41 PM
  2. Help with e-stop button
    By Astroguy in forum Xylotex
    Last Post: 05-31-2007, 01:23 PM
  3. Where do I install an emergency stop button?
    By alexccmeister in forum Stepper Motors / Drives
    Last Post: 04-22-2007, 12:40 AM
  4. Arcade Button Emergency Stop
    By mikkojay in forum Gecko Drives
    Last Post: 06-07-2006, 06:30 AM
  5. Cycle Start button
    By kaleem1 in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 09:05 PM
