na it will be cheaper Ian the chinese government alway Help those who pay lots of tax and toe the line and give there self a good internation name selling top notch products.
http://danielscnc.webs.com/
being disabled is not a hindrance it gives you attitude
[SIGPIC][/SIGPIC]
jips Roger is right that motor to spin the carousel is far too big A big nema 23 would work or a small servo motor,
[SIGPIC][/SIGPIC]
lol. need to say that the point is not driving the carousel rotate, but the acceleration. We always hope the ATC work faster to save machining time as we are talking about an effective ATC machine. We may want the ATC changes a tool in 3-5 seconds. It needs the carousel accelerates fast and then needs more strength from the motor. So it has a good reason here to use a big motor.
www.skyfirecnc.com
Email: [email protected]; Skype: skyfirecnc
OK, good point.the point is not driving the carousel rotate, but the acceleration.
That's essential. The average home or garage (here in Oz) does not have 3 phase. I do, but I live on a farm, and even so I had to ask specially for it. You could look at having a 240 VAC 15A connection quite easily, or two 10 A outlets in use, but for many that would be the limit.the ATC prototype in the picture I will run with 220VAC single phase.
Very, very true. The big electrolytic caps are the first failure point for a lot of gear. It is always worth while using 'oversize' caps with very low ESR in an industrial system.VFD/VSD should use the capacitors specially for VFD. It's not the same thing as common industrial capacitors---even they have same volume and voltage, temperature specifications. Common capacitors will ageing fail soon in VFD after a year or so.
Looking good so far.
Cheers
Roger
yer the power supply stuff seems to be your only problem what is good, easy to fix. if you just have a question for anyone who buys one of your machines asking what rating is there power supply it would make life a bit easyer.
you don't want to spin your atc to fast or you will have to add a locking mechanism.
[SIGPIC][/SIGPIC]
Hi.......as far as I know......you can get 3 phase for your domestic abode by applying for it on the grounds that your air conditioner is more than 2 HP and can't run from the single phase supply without tripping out the breaker each time it switches on......then get your favourite electrician to run and supply the necessary 3 phase connectivity to the garage.
A few years ago, with a Bridgeport mill purchase and a hack 3 phase converter that was actually a 2 phase lash up and made the motor get hot, I bought a 3 HP rotary phase converter.
In the mid 90's I ran a 3 HP single phase motor on my capstan lathe doing sub contract work on the side, and every time that switched on the lights dimmed, the TV and anything else got a hiccup from the sudden mains surge.
I cured it by fitting a 12 volt electric clutch, gleaned from a cars air conditioner, and only had to switch on once in the session.....the 12 volt clutch only took 2 amps to activate but was capable of handling 4,000 rpm + and quite a few HP.
Ian.
Probably, but have you priced it?.you can get 3 phase for your domestic abode by applying for it on the grounds that your air conditioner is more than 2 HP and can't run from the single phase supply without tripping out the breaker each time it switches on.
That's a whole new lead-in from the street, a new meter box, two more power meters inside the box, new Council fuses, plus the 3-phase wiring you have to snake through the house somehow. Plus the cost of the Council connection at the street. Mucho $$. - almost as much as the CNC!
Cheers
Roger
Here $5 grand if you work for the electricity company most of that is just the cable to the house, if not a hell of a lot more, it will be about the same over your way
[SIGPIC][/SIGPIC]
Do you only have 1-phase electricity coming into the house from the outside? It must be a really fat cable coming in... Here, we have 3-phase coming in to the house and then it is split into 1-phase circuits in the breaker box.
they use to over here they changed it years ago you ever have single or 3 now most have single no it`s not a big fat cable
[SIGPIC][/SIGPIC]
Hi Stigoe
Different countries, different systems. Most domestic supply in Oz is single phase, probably something like 40 A or so. No, it's not a very fat cable.
It may be that in Norway the supply is a little heavier for heating purposes?
cheers
Roger
So you have a 1-phase 40A coming in to the house? Wow! I have a 3-phase 63A into the house and I don't think that is uncommon in normal houses here. But yes, we do use it for heating and kitchen appliances. No natural gas here, strangely enough, considering how much much we export of it.
Hi Mactec
I find that a bit astonishing. 400 A single phase into the house???? That's busbar territory.I say wow as well, the 240v single phase I have is 400A,and can have more if I want/need it, the normal modern home in the USA has a 200A supply, we use gas mostly for heating
There is no way our supply authorities would ever permit such an unbalanced load. You would be told to go 3-phase, and you would also be required to balance your load across the phases. otherwise you risk blowing the transformer. Yes, they run 3-phase down the street, and alternate the phases going into houses. Have to, to balance the tranny.
Um - I thought the USA was 110 VAC, not 240 VAC. Where-abouts in the USA do you get 240 VAC?
EDIT: now 120 VAC, I find. And I now understand the unique USA split-phase system. Only in the USA ...
Cheers
Roger
you have lot`s of snow and really needed heating so not surprised you have higher power need, down here in NZ and Au not that bad
[SIGPIC][/SIGPIC]
I don't even have 3 phases of power available on my street. If I wanted three phase power, I would have to pay the electrical company to bury more than 1000 ft of new power lines (we have underground services), and it would probably cost me upwards of $30k.
That is pretty typical for most residential power distribution systems in the US. The power company has three phase power feeding major roads, and than pulls a single phase off that (through a multi tap transformer) to run down a street to provide power to the houses on that street.
Tim
Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
Yes the USA sucks as far as 3 Phase power is concerned, but you also pay more for it on top of the high installation cost, even for an industrial install is big dollars, It's best to stay with the 240v single phase and install a Phase Perfect, that's what I did, It is rated at 80A 96A max this is with the PT380 unit, total cost around $8,000 these units are around 98% efficient, so much better than anything other method to get 3 phase power if you need it, and you still pay the low cost for power used
Mactec54
