Hi.......I have a small bench type drill press with a 1/3 HP single phase motor........it can drill 12mm in steel.....maybe the way I sharpen my drills helps.
Perhaps it's not relevant because the speed changes are by multi step pulley diams and belt drive so the torque is multiplied the smaller you go down on the drive pulley.
I've also got a larger semi pedestal drill press and that has a 1/2 HP single phase motor........drills 12mm in steel with ease, but you can stall the motor if you hang on the handle too heavy........usually I pre-drill with a smaller drill anyway otherwise the table deflects down a bit, but a scissor jack under it helps.
I would expect the SVM-0 to drill 12mm in steel, probably with a smaller pre-drill size as I like my holes to be round, smooth and on size rather than oval or triangulated.........I'll test that when I get to it.
At the moment the mill is set up with the higher speed pulley, so going down on the revs electronically for HSS drills will lose a lot of HP or torque....whatever.
The convenience of electronic speed control is offset by the lack of torque when you go down in the revs.
I have to wonder how much better it would be to have the spindle speed controlled by infinitely variable type pulleys and a speed sensor, despite the need to vary speed in a program electronically for various cutter sizes, but that would only apply if an ATC was in the picture......pausing in the middle of a program and changing tooling is a manual affair and so could a vario pulley be too at the same time..
It will be a big hassle to change over the pulleys on the SVM-0 to the smaller drive one for more torque just to drill a bigger hole or two......having the power draw bar on top of the spindle doesn't make it any easier to swap over belts and pulleys.....but it might be easier than I think if the whole PDB housing is slipped off........3 screws etc.
Ian.
