Originally Posted by
stewi
Hi Skyfire,
it is going to be a sand cast, so you don't need to win a beauty contest in your paint job.
I'm more concerned about where you depart the mold plug from the top and bottom sand box. Currently, it appears to depart on the top edge, which will create quite some flashes on these edges.
To my humble experience it is better to make the departing line in the middle of the bottom flange at a vertical surface and than taper that flange to both sides up and downwards.
However, happy casting!
Regards,
Stefan
