587,998 active members*
1,956 visitors online*
Results 1 to 5 of 5
    Y and Z axis inverted on offline Controller
    hi guys i am a complete rookie in cnc world. Where i work , we buyed a twotrees cnc (TTC450) we have installed all drivers, but we have the z and y axis inverted on the offline controller, while the x axis is good. Can you please give me a solution and what's causing this problem? Thank you in advance.
    Dec 2005
    601
    Re: Y and Z axis inverted on offline Controller
    What controller?
    Quote Originally Posted by mattia_marfelli_03 View Post
    Attaching photos or videos could be more easy to understand the problem.
    like cnc and driver model names, alarm codes on cnc and drivers, etc.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    The controller is the makerbase dlc32 v2.1 but is from another producer, because the TwoTrees give us the TTC450 cnc with a defective motherboard and we've changed. We buyed a new makerbase dlc32 v2.1 from amazon. The monitor is the MKS TS35-R V2.0 and is all the same but now Y and Z are inverted when i use the controller or grblesp, for example, If i click the "up arrow" the Z will go down and is the same thing with the Y axis.
  1. Offline controller
    By rp-beech in forum Controller & Computer Solutions
    Last Post: 03-15-2023, 12:03 PM
  2. DDCSV1.1 offline controller
    By chopper13 in forum Want To Buy...Need help!
    Last Post: 12-31-2017, 10:42 PM
  3. X y axis inverted.
    By JET-X in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2016, 11:42 PM
  4. 50KHZ CNC 4 Axis offline controller, PC alternative
    By MrChips in forum Stepper Motors / Drives
    Last Post: 12-27-2015, 11:58 PM
