603,308 active members*
2,605 visitors online*
Results 1 to 5 of 5
    Y and Z axis inverted on offline Controller
    hi guys i am a complete rookie in cnc world. Where i work , we buyed a twotrees cnc (TTC450) we have installed all drivers, but we have the z and y axis inverted on the offline controller, while the x axis is good. Can you please give me a solution and what's causing this problem? Thank you in advance.
    Dec 2005
    619
    Re: Y and Z axis inverted on offline Controller
    What controller?
    Quote Originally Posted by mattia_marfelli_03 View Post
    Attaching photos or videos could be more easy to understand the problem.
    like cnc and driver model names, alarm codes on cnc and drivers, etc.
    The controller is the makerbase dlc32 v2.1 but is from another producer, because the TwoTrees give us the TTC450 cnc with a defective motherboard and we've changed. We buyed a new makerbase dlc32 v2.1 from amazon. The monitor is the MKS TS35-R V2.0 and is all the same but now Y and Z are inverted when i use the controller or grblesp, for example, If i click the "up arrow" the Z will go down and is the same thing with the Y axis.
    Little late but if you didn't solve you can set it with command $3.
    https://github.com/gnea/grbl/wiki/Gr...rt-invert-mask
  1. Offline controller
    By rp-beech in forum Controller & Computer Solutions
    Last Post: 03-15-2023, 12:03 PM
  2. DDCSV1.1 offline controller
    By chopper13 in forum Want To Buy...Need help!
    Last Post: 12-31-2017, 10:42 PM
  3. X y axis inverted.
    By JET-X in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2016, 11:42 PM
  4. 50KHZ CNC 4 Axis offline controller, PC alternative
    By MrChips in forum Stepper Motors / Drives
    Last Post: 12-27-2015, 11:58 PM
