587,887 active members*
3,206 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > MR-J40A servo amplifyer - Need help to change Servo loop type
Results 1 to 2 of 2
    Jul 2013
    Hi everybody,
    I can not change the value of Pr01 (Servo loop type: STY) from speed (0001) to position type (0000).
    I looked out the relevant in the manual:
    Section 3.11 “these are validated when the power is cycled after setting”
    Section 4.3 “defines whether the diriver is a position or speed type”
    After set STY from “0001” to “0000”, then turn OFF and turn ON the power, the display is still “LP-V” and everything does not change.
    Whether it fault or there are some settings else?
    Thank you.
    Sep 2008
    93
    push the emergency stop button, then try again
  1. Change from yaskawa servo to delta servo
    By sachin.kumar in forum Servo Motors / Drives
    Last Post: 11-02-2012, 06:31 PM
  2. servo feedback loop
    By bdrmachine in forum LinuxCNC (formerly EMC2)
    Last Post: 03-24-2012, 01:14 AM
  3. Servo closed loop specifics
    By stevespo in forum Gecko Drives
    Last Post: 12-13-2009, 05:27 PM
  4. Servo Power and loop error?
    By 123CNC in forum LinuxCNC (formerly EMC2)
    Last Post: 09-23-2008, 02:55 AM
  5. question on closed loop vs open loop (servo systems)
    By boonie in forum Servo Motors / Drives
    Last Post: 11-09-2007, 07:30 PM
