Hi Everyone,
I work for a company that regularly cuts sheets of 9mm Laminated Plywood and raw plywood into panels of varies shapes and sizes.
What would be the best tool to use for this type of wood, previously we have used a 2 flute straight cutter as we often do pocketing as well as full depth, however we go through tools like they are going out of fashion. We are looking into a up cut down cut compression spiral tool at the moment, would like to hear if you have any suggestions on this? With this tool, I understand drilling isn’t an option, for internal profiles, is it possible to automatically drill the start position so that the cutter can go through the hole and start cutting?
