587,125 active members*
3,174 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > 60 watt laser (redsail ?? ) possibly imitation?? NO power at all !!
Results 1 to 2 of 2
    Sep 2014
    7
    Hello,
    I am hoping for some kind of direction. I recently purchased a 60 watt co2 laser and upon receipt and setup I plugged the laser in and tried to turn on the power. Nothing happened. The light inside the cabinet wont even come on. I checked the fuses at the power cord they are fine. I checked the e stop button it is fine. I used a volt meter and checked to make sure the power cord was good and I am getting 120 v coming out of the e stop and power switches. My question i guess is that there is a label on the power supply that is for switching from 220v to 110v . It is in the 110 v location per a sticker but i am wondering if the sticker could be on upside down ? Should I try flipping the switch to the other location ? Any other help would be greatly appreciated.
    Nov 2010
    787
    Re: 60 watt laser (redsail ?? ) possibly imitation?? NO power at all !!
    Quote Originally Posted by mrichards View Post
    Hello,
    NO. Use you volt meter and check if you have 120V on power supply input and any (DC) voltage on power supply output.
    CNC lasers, constructions, service
  1. redsail 60 watt laser
    By vicsrc in forum Redsail Laser
    Last Post: 09-30-2015, 06:36 AM
  2. New 150 Watt Laser loosing Power. Hair pulling continues!
    By Roarockit in forum Laser Hardware
    Last Post: 05-17-2015, 11:23 PM
  3. No power to 50 watt chinese laser.
    By jeff4freedom in forum Laser Hardware
    Last Post: 02-18-2015, 04:04 PM
  4. Minium Power from a 100 and 150 watt laser
    By MonoNeuron in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-01-2011, 03:43 PM
