587,754 active members*
2,815 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Power Draw bar won't clamp tool from ATC
    Apr 2013
    27
    Hello all,
    I was going thru a setup with my PCNC 1100 today, I initiated a tool change for storage. When the ATC loaded the tool to the spindle the power draw bar didn't clamp it. I tried it again with the next tool in line and the same thing happened. I did a test in the ATC setup screen and found that when I press the draw bar up button nothing happens. When I press the down button it works. I can work the draw bar with the button and foot peddle. This a new machine and I just got it setup so I think possibly a bad sensor? I just ran a practice part the other night and all went well including tool changes. Any ideas?
    Pete
    Jan 2007
    869
    Check all of your wiring. I had the same problem at first and I mis-wired something.
    Also, check all your fuses and the mounting of the daughterboard.
    Also, call Tormach. They will help you thru it.
    Wade
    Mar 2013
    10
    yea maybe the switch is not making contact. check your air pressure hasnt drop, haas vf series has issues like that .
    Apr 2013
    27
    Thanks guys, it was a bad wire connection as you suggested. All is well now!!
  1. Power Draw Bar for NM-145
    By cteufert in forum Novakon
    Last Post: 07-17-2014, 08:21 AM
  2. Power Draw Bar
    By Blakea1790 in forum Tormach Personal CNC Mill
    Last Post: 11-10-2011, 09:56 PM
  3. Power Draw Bar for 770
    By oknups in forum Tormach Personal CNC Mill
    Last Post: 01-27-2011, 02:05 AM
  4. Power Draw Bar and Table Mounted Rack Tool Changer?
    By David Bord in forum Tormach Personal CNC Mill
    Last Post: 08-12-2010, 03:16 PM
