587,221 active members*
3,079 visitors online*
Thread: Axis Faults.
Results 1 to 2 of 2
    Apr 2015
    Unhappy Axis Faults.
    Hello,
    I use a FADAL 3016L made in 2004 at work. I have been having several issues with it so I have several questions.
    Short version:
    1. What is the recommend warm up for a FADAL?
    2. What would cause the Y axis to CS to a position .190 away from where it used to?
    3. What would cause Y axis fault "Axis controller does not respond to NC" and Z axis fault #21, "Spurious interrupts not serviceable."?
    A little while back, when I powered on the machine, after taking off the E-Stop the machine ran forwards in the Y axis until it hit the mechanical limit and got stuck. Motor override errors were given, and I ended up having to put a socket wrench on the nut on the end of the Y axis screw to break it loose and move it.
    Since then, the new CS home has been .190 from where it used to be. That offset has been consistent. If I jog it to where it used to be homed and run CS, it moves over that .190. It has done this consistently since then, so I have been continuing to use the machine just with a new home that is .190 away from where it used to be.
    Last Friday after I started up the machine, I let it set for about 20 minutes. After then I ran CS, let it sit for about another 20. When I was sending the machine to its second home position, (7.5 inches along the Y to move the vises near the doors) the machine moved about 3.9 inches and gave a "Y axis fault Error #3 motor overload" After jogging it back to the CS location, and power cycling I didnt have that issue again. At this time, with the machine powered off, I made sure the Y axis board was seated well, and I unplugged and reinstalled the wires going it to.
    Later that day, as I was setting up a fixture, I had the fixture set too far left causing the program to run out of travel on the X axis. When I received the "X AXIS fault - position limit" The Y axis would run away and travel to the back of the machine throwing up a "Y Axis fault Error #3". When I moved the fixture, this problem disappeared. The machine ran fine for the rest of the day.
    Tuesday morning, I started up the machine and let it sit for about 20 minutes. Then I ran CS, and let it sit for about another 20 as I was doing other tasks. When I returned to the machine I found it had a Z axis fault #21, "Spurious Interrupts". After powering down and restarting the machine I had no issues or problems for the rest of the day.
    This morning, 2 days later, I power up the machine and ran CS. Half an hour I did a dry run then started running parts. After running for about an hour I had a Z axis fault #21 after a tool change. The Z axis was traveling down when the fault occurred. The machine ran fine for an hour, then the ATC would not move to the spindle. I power cycled the machine and it appears to be functioning correctly again.
    My Y axis issues seem to be in the mornings, and when the machine warmed up I didn't have any more Y axis issues. Could this be caused by an insufficient warm up?
    My company is ready to call a tech out to look at the machine. I want to better identify and understand the issue before we do that. Any suggestions or comments? Anyone have a FADAL rep they can recommend that would be nearest to Sarasota Florida?
    Thank you.
    Apr 2015
    Re: Axis Faults.
    The day after I made this post I went and pull the wires to the Y and Z axis boards and reinstalled them. I also jiggled the boards to make sure they were seated well. Since then I have had no issues.
    So hopefully it was just a loose connection somewhere.
  1. Tree Journeyman 310 - Z axis faults
    By num1bryanp in forum Tree
    Last Post: 01-25-2013, 05:57 AM
  2. G540 Faults if i plug in more than 1 axis
    By jandalaser in forum Gecko Drives
    Last Post: 04-21-2012, 05:53 PM
  3. Z axis faults and falls to table
    By imaginemw in forum Fadal
    Last Post: 02-04-2012, 02:08 AM
  4. Y axis resolver/over temp faults
    By smittys800 in forum Fadal
    Last Post: 06-11-2009, 05:57 AM
  5. Replies: 7
    Last Post: 10-24-2007, 08:08 PM
