Also posted on MachSupport Forum.
I have a client system running Mach3 on a router:
32 bit Windows XP SP3
On-board parallel port
PMDX boards interfacing between PC and OEM controller cabinet
Stepper motor/ballscrew axis drives
Problem: After a 4 month period, trying to run previously proven code, the machine axis moves are jerky when running code, but move normal in jog mode.
I have read various threads with similar symptoms, and have applied, or checked for the many solutions presented in those threads... with no improvement on this system.
Items checked:
CV-Exact Stop, and Look Ahead setting in Config (no change)
G8 entry in code (none present)
G1 after previous G0 (correctly placed in code)
Motor tuning Vel and Acc set correctly for previous proven code runs
Driver Test reports System Excellent
Re-installed most recent Mach3 release
Initialization in code:
G20G64G17
G90
G91.1
Non of the equipment was powered up during any storms/blackout/brownout
Attached are the .xml, and a video of the X-Y axis jerkiness while running code
I have run out of ideas for checking a system that ran fine the last time it was powered up.
Any help ideas will be tried quickly and results reported back here.
Thanks, Paul
