Homemade Mini CNC Milling Router Mill DIY Z Axis Slide Stage Frame Aluminium
Materials for Z Axis DIY 100 mm travel
Collet ER11 Spinde DIY
1 pcs Aluminium 200 mm x 82 mm x 10 mm
2 pcs Aluminium 42 mm x 82 mm x 10 mm
1 pcs Aluminium 90 mm x 82 mm x 8 mm
1 pcs 150 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm, Length 150 mm with Copper Nut
More Homemade Mini Robotic Arm Laser Engraving Cutter DIY 3D Printer Machine Frame here:
1 pcs Nema 17 42BYGHW811 0.48N.m(70oz-in) 48mm 2.5A for 3D printer
1 pcs ID6.35*8mm D19*L25 Aluminium CNC Stepper Motor Flexible Shaft Coupling Coupler
2 pcs 12 mm 12 x 200 mm linear shaft 3d printer cylinder linear rail linear shaft axis cnc part
2 pcs LMK12UU 12mm flange bearing CNC Flange Linear Bearings Flange Linear Bush
https://youtu.be/C-0rAIiDE7s
https://youtu.be/bz_Lv-lDwhI
