587,473 active members*
3,568 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal 3016 LED monitor upgrade VGA
Results 1 to 8 of 8
    Feb 2011
    19
    I've read everything I can find on here and everyone seems to have a BNC connector on their Fadal. I have a 2003 with 1990-1C pendant board. It has a VGA output and I've been trying to find a wiring diagram that tells me what the outputs are, or someone that makes an adapter cable to a standard 15pin VGA to fit my LED monitor.
    Has anyone successfully connected a LED monitor to the Fadal VGA output?
    Aug 2009
    1573
    Re: Fadal 3016 LED monitor upgrade VGA
    Feb 2011
    19
    I've seen all those, and those are standard cables and not made for the Fadal.
    the question is has anyone made a newer monitor (VGA-HDMI-AV-BNC) connect and work with the VGA output from a Fadal?
    I've found zero info on the VGA pinouts and if anyone has made this work.. I'm not willing to just attach wires and possibly short something out.
    Jun 2005
    1730
    Here are the details on the VGA connector and what each wires function is for that interface.
    https://en.wikipedia.org/wiki/VGA_connector
    It has been a longtime since I have used a BNC monitor cable, but as I recall that is the same as an old composite signal, which used to be a yellow cable with an RCA plug.
    Russ
    Feb 2011
    19
    I appreciate that link, but I need the pinouts from the Fadal board to make that work.
    Attachment 479098
    Jun 2005
    1730
    Here is a guy to installed a new LCD display for a Fadal.
    https://www.cnczone.com/forums/fadal...-93-vmc15.html
    Aug 2009
    1573
    ...for want its worth here is some photos of 2005 Fadal 4020 VGA factory setup
    Feb 2014
    227
    Little late to the party. GOTO itscnc.com look for resources, wiring diagrams and look through the choices and you will find the answer. Your machine was prewired with a VGA cable already more than likely. I had to get the VGA board for the bird cage to replace my old board for color monitor and buy the extra VGA board in the pendant. I wired up a lcd monitor screen with VGA for the vmc screen and use the new monitor remote to change I put to USB for the NUC computer in my pendant. Works great! I can get on the net right from the Fadal with no issues and is a wireless. I got the same monitor as Aaron Gouge. The monitor was $110 from alibaba. Well worth the money as the color screen is nice.
    If you need any help let me know.
    Jeff
  1. Vise size for a Fadal 3016
    By Recoil6 in forum Fadal
    Last Post: 04-07-2019, 05:51 AM
  2. Electra Supercut 734 WEDM - No Signal to VGA Monitor
    By IMSSupplies in forum EDM Discussion General Topics
    Last Post: 03-24-2016, 01:22 PM
  3. Fadal VMC 3016 I Need Help PLEASE!
    By HBZ USA in forum Fadal
    Last Post: 08-07-2010, 07:11 PM
  4. tutor for fadal 3016 w/ 88 control
    By Runner4404spd in forum Employment Opportunity
    Last Post: 02-25-2009, 10:13 PM
  5. Reman Fadal 3016 Questions
    By RDTS in forum Fadal
    Last Post: 11-20-2008, 04:12 PM
