587,997 active members*
1,862 visitors online*
Results 1 to 2 of 2
    Mar 2013
    3
    Fixed gantry design table question
    I am working on a fixed gantry diy build. I have a 66” gantry (i beam), with just over 52” of ballscrew travel . Vertical legs mound under the i beam, so im looking at a table width of 48”.
    The original plan was to use the conventional two linear rails, spaced around 32” apart, screw in the middle, table on top. I’m kinda worried about the table deflection in the center, as it seems that likely were a majority of the work will be done. I was going to do a mic 6 table, but that stuff is getting Real expensive, seeing as i likely need it to be around 1” thick, 48”x48”. I can make some kinda boxed in table with 1/4” plate and a bunch of 8020 i have laying around , spoil board on top.
    most of my work will be wood, plastic exc, but i do the occasional. 1/4” aluminum plate. (Currently ,On my existing smaller machine ).
    Any suggestions on a decent table build i dont have to drop a grand on? Does using 4 rails on the table make any sense? . This would also be expensive as they are going to be quite long.
    Jul 2018
    6503
    Re: Fixed gantry design table question
    Hi Shmuu - investigate some ground steel. Steel is cheaper then aluminium and 3x stiffer. Or 3 rails will help. You don't have to move the table in the middle the drive can be offset...Peter
  1. Fixed Gantry Design
    By CatalystGilles in forum DIY CNC Router Table Machines
    Last Post: 06-05-2018, 06:18 PM
  2. Need help - Fixed gantry design
    By boltzzz in forum Mechanical Calculations/Engineering Design
    Last Post: 01-01-2018, 03:14 AM
  3. Fixed Gantry Design Question
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 04-22-2012, 10:26 PM
  4. Small Fixed Gantry Design
    By praneetn7 in forum DIY CNC Router Table Machines
    Last Post: 03-26-2012, 05:08 AM
  5. 8020 Fixed Gantry Design
    By jupdyke in forum DIY CNC Router Table Machines
    Last Post: 12-30-2010, 11:48 AM
