603,893 active members*
4,653 visitors online*
Thread: G76 thread
Results 1 to 2 of 2
    Aug 2018
    5
    G76 thread
    At work we have a HASS st20 and st25 which use single line G76 however I can't find the spring pass setting is it in there somewhere lol?
    If not can I use the 2 line G76 so I can specify the amount of spring passes?
    Nov 2007
    1704
    Re: G76 thread
    There is a setting for minimum pass size but, if you want a spring pass or multiple spring passes, G92 is what you seek:
    https://www.haascnc.com/service/code...value=G92.html
    Make sure to use the same Z start point and parameters as your G76 but, enter the X value for each individual pass you want to add.
    Greg
  1. G76 Thread help
    By osubucksfan09 in forum G-Code Programing
    Last Post: 03-16-2020, 03:25 PM
  2. G76 Special Thread
    By Gandoril in forum Fanuc
    Last Post: 01-17-2019, 07:15 PM
  3. g76 thread cycle
    By warcnc in forum G-Code Programing
    Last Post: 02-03-2013, 11:32 PM
  4. Multi_Start Thread using G76
    By JerryH in forum Fanuc
    Last Post: 12-23-2012, 05:06 AM
  5. G76 Thread Cycle
    By eliot15 in forum G-Code Programing
    Last Post: 03-27-2011, 04:01 PM
